587,418 active members*
3,758 visitors online*
Thread: Type3
Results 1 to 2 of 2
    Nov 2010
    15
    Type3
    When I create typeart object and click on the "section icon" it shows the engraving ABOVE the material (z+) rather than IN the material. Then when I create a toolpath and try to machine it I get an error that Z+ is over limit. What is wrong? Any help appreciated.
    Apr 2011
    0
    Hi andus!Just move a litle bit the object and press F2 at the same time.Then check an origin in the new window (I usually make it at the low left corner) and set the x,y,and z distances-if z is not set properly (like zero) then you have problems.
    I hope this helps!
  1. Type3
    By Hardywood in forum Uncategorised CAM Discussion
    Last Post: 12-28-2012, 02:38 AM
  2. English manuals for Type3 and NCStudio please
    By andus in forum Chinese Machines
    Last Post: 11-19-2011, 01:00 AM
  3. who knows something about type3?
    By vikki007 in forum DIY CNC Router Table Machines
    Last Post: 12-31-2010, 06:09 AM
  4. Need type3 software information
    By rdludlow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-20-2010, 03:36 AM
  5. Type3 software
    By evertongodoy in forum Uncategorised CAM Discussion
    Last Post: 07-12-2010, 01:42 PM
