587,722 active members*
3,617 visitors online*
Results 1 to 5 of 5
    Mar 2005
    116
    Two stepper on one drive
    Quote Originally Posted by pminmo
    Yoram,
    Look at the 3 axis system diagram on my website: http://pminmo.com/
    Really boils down to what software you are going to run. Also on my website here:
    http://pminmo.com/pport/pport.htm
    You can see how EMC runs six motors on one parallel port.
    Phil
    Phil, I've decided to start a new thread since the other one has already more then 62 pages. :-)
    I want to asure you that I've been looking at your web page a lot. :-) You can see it by the questions I've asked about the chip selection.
    I'm going to make a foam cutting cnc and the software for it is runnig four axis. If I use the same machine to route I'll need the x and the z axis motors to be run together. If I'll use Mach2, which I probabely will do, then I have to connect the motors together. On an other thread I saw some one say that he has two motors connected to one driver and with the power off when he turns one motor the other one follows. Way cool. :-) The motors I hope to have run on 1.5A. So my question is how do I connect two of your boards to one output? Just run a Y wire from the breakout to the drivers?
    I'm talking of course about the a3977sed boards
    Yoram
    Mar 2005
    73
    I saw your post here so I had to reply.
    That was my controller I had 2 motors on 1 driver...Oh and by the way I ran this with windows 98 and Linux EMC with no problems. The way I did it was set up EMC on Linux first. The directions I wanted for X,Y and Z then rebooted into windows and setup Kcam and flipped the printer ports so they went the same way I had them going in Linux.
    Send me a message if you feel like it...I am no pro but I do have
    some ideas I like.
    Hope I helped in some way
    "life is short"
    Mar 2005
    116
    What you did is you connected the two motors in parallel to the driver. If I will do that with two 1.5A motors connected to Phils board which is rated for 2.5A I'll go over its rateing. It may work if I add extra cooling to the chip but I'm not sure if you can do it. I don't mind having 5 drivers for 5 motors if I know how to connect them.
    Yoram
    Jun 2003
    3312
    Yoram,
    I wouldn't advise one 3977 output to two motors. A biploar driver chip supplies the motor voltage unlike a uniploar which most of the time just switchs the ground side. You really ought to use on driver per motor. You can parallel the inputs. i.e. one step signal from the pc wired to two step inputs on two driver boards.
    Phil
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2005
    116
    Thanks, Phil, that's what I wanted to know, if I can double up on the breakout board's output.
    Yoram
  1. Direct drive with stepper on rack and pinion.
    By jerryrigge in forum Linear and Rotary Motion
    Last Post: 10-10-2007, 03:21 AM
  2. Stepper As A Lathe Spindle Drive
    By mklb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-18-2007, 04:47 AM
  3. Stepper drive question
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 03:55 AM
  4. Need a low cost 4 amp, 48 volt, stepper drive
    By Mini Miller in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 08:29 PM
  5. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
