I need to make the assembly shown in the picture. As you can see it telescopes out each end and has a crimp in the center. It's 35" closed and 63" extended, tube od is .625 and .500 aluminum. All of the crimps appear to have been rolled into the tube. The inner tube has a bead that keeps it from falling out past the crimps in the outer tube. What type of machine do I need and who makes it. I have spoken with a couple of manufacturers and the ends are not the problem its the crimp in the center that can not be done on the end forming machines I am finding. I only need to make about a thousand pieces a month so I don't want to invest 100 grand on equipment. Ideas or suggestions of any kind on a method of doing this would be greatly appreciated.
Thank you
