This is regrading X Form, Offset Contour. This is in MC X-4.
I select the Offset Contour operation, the Chaining Selection Box comes up and I select the chain or chains I wish to resize and click the Green Arrow.
Then the Offset Contour Box comes up and I input my changes.
Now, get this. The Offset Contour Box is so tall on my screen, the Green Arrow Button is blow the edge of my monitor. Even when I shift the Task Bar to the side of the monitor, the Offset Contour Box is still too long and doesn't expose the Green Check Button. I can't confirm this op.
I fooled around with screen resolution, but to no avail. I will be humbly embarrassed and thankful to be told how simple the fix to this becomes
