I'm the newbie on the block, so go easy... I am building my 1992 Toyota MR2 (I'm also on MR2OC.com and TwoBrutal.co.uk), I have torn apart the transmission because I am either going to replace it with a better version or stronger more reliable gears in this one. The transmission is Toyota's S53, minor variations but same as S51-S54. I'm looking at keeping the transmission as a five speed gear box but since I have this one taken apart, I though about going back to class to CNC some new gears. As it's know, the gears are cast iron, I'm looking for something at least as strong but lighter. My understanding is, typical power lose from flywheel to the wheels is 15%, I'd like to try to minimize this or be able to put more power through without stripping teeth. I was thinking dog gears. The gear ratio's are as follows...
A 5-Speed Manual Transmission.
Ratios:are not fin
First Gear: 3.285
Second Gear: 2.041
Third Gear: 1.322
Fourth Gear: 1.028
Fifth Gear: 0.820
Reverse Gear: 3.153
Final Drive: 3.944:1
Applications:
Toyota Camry
Toyota Celica
What I'd ideally want...
First Gear: 2.041
Second Gear: 1.322
Third Gear: 0.918
Fourth Gear: 0.731
Fifth Gear: ???
Reverse Gear: 3.153
I'm only going into my second semester of CNC, 3rd out of machining, I have not clue as too where to start.
