I'm making 4 small parts at a time. They are the same parts. I will use 3 tools. I do not want to do a single part with three tools and then switch to the next part. I want to use tool 1 on each part, then switch to tool 2, use it on each part, and finish the parts with tool 3. This will save quite a bit of tool changes and time. In the past I have done this by copying each individual operation, and changing each individual offset within that operation. This takes quite a bit of time when there are 20 operations with 4 different offsets. 20 x 4 = 80 individual work offset changes. Also, if I need to make a change on an operation, I have to make that change on all 4 of the operations. Is there a better way to do this? I'm using X3.
I want to be able to tell the machine to run all the operations on tool 1, 4 times on G54, 55, 56, 57. Then switch to tool 2, 3 ....
Thanks,
- Andrew
