Build 1547 V27
Translate drag does not work
Translate Delta is no longer there
Anyone else ?
Let me re-word it,it does not work in a user friendly way.
Build 1547 V27
Anyone else ?
I've read the build notes and there's no mention of problems in Translate -
http://bobcad.com/wp-content/uploads...Build_1547.pdf
- Nick
Have you tried it ?
It works but is lame
maybe it will get better once use to it,,,I hope
I have Build 1462 and the drag and Delta work fine here, must be one of those "do something new and break something old" that they seem to be fond of doing
The translate has been solid since V23 from my recollection
Regards
Rob
:raifro: :rainfro: :rainfro:
Using 1547 but hardly ever use translate so not sure if its not as good as before but drag seems to be working fine.
Just opened a solid in BobCAD, clicked translate then selected the model, right click OK then the coords handle pop up and I can drag no problem. Maybe it was different before?
Hood
Could be a case of "got myself a new computer and video card".....
I am on build 1547 and it does not work as it did for me either.
The drag button appears to do what the delta did, but no other option for delta/drag available.
Jrmach....Translate drag works...but differently. I had the same question and someone at bobcad enlightened me. I have V27 build 1547. Translate drag...start the command, pick what you want to move and do you see the little ball at the center of the XYZ icon?.....select the ball and you can move the item you selected. Also on translate delta...select the sketch/enter command and have start pick and end pick set to the enter button. Then it is a full delta move. Hope this helps. Have a great day.
I like the translate of V27.0.0 better than build 1547.... If anybody important cares!
