Re: Torus Pro As A "Production" Machine
Originally Posted by
SCzEngrgGroup
...You must make all six pieces, from a single piece of stock, in a single, un-interrupted run of a single g-code program....with NO operator intervention
Are you using a vertically mounted rotary table? Because it looks like both the top and bottom required machining,
EDIT: We are missing a critical piece of information: size. RCaffin suggested using a t-slot cutter to do the undercut with-out flipping, which would work up to a certain size part. I was thinking this was a larger piece.
"Lift Sensor Bracket". So I am guessing this is indeed small. Did RCaffin win the prize?
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
