I am sure you will prefer higher spindle speed of Torus Pro which is higher than Tormach's , and more easily to access just by the using the VFD . You don't need bother to change the pulleys when yours program requires different range of speeds .
Max.500IPM movement of the 3 axes is also a plus for this mill .
I think the ATC or PDB is definitely a good assy to be added .You can save more time when change the tools .I guess Novakon will release theirs in one month or sooner , which can be added whenever you want .
