I want to lower and raise the head on my Torq-cut 22 by hand to check if there is any dragging on the ways. Does anyone know of any easy way to do this? I have ran it down a few inches by removing the brake and hand turning the belt sprocket but I want to run it down much further to see if the ways are dragging further down. I am thinking about making a hand crank to fit the splines where the brake mounts but I thought I would check here first to see if someone has a nifty trick.
