587,163 active members*
3,366 visitors online*
Results 1 to 6 of 6
    Jul 2022
    9
    Question Tornado T220 Turret Error Fanuc
    Hello guys,
    I have a problem as I mentioned in the picture, when I freeze the turret manually, this problem disappears, but when I restart it comes back. The axis battery was dead. I did X and Z reference resets but not to the Turret. why am i facing this problem.
    Jan 2013
    474
    Quote Originally Posted by Hunterk2 View Post
    Hello guys,
    Does your turret usually unclamp to turn ? If so, it could be it's not properly unclamped and can't turn. It looks like there is an overcurrent because the turret is jammed and not referenced for the same reason. When you re clamp the turret the drive disables so error goes away.
    I would check the turret clamp/ unclamp first.
    Jul 2022
    9
    Re: Tornado T220 Turret Error Fanuc
    I checked the clamps, everything is fine, the turret turns. B Axis APC DOES 1, it says the battery is dead and asks for a reference, but I just changed the battery, when I set 0, this warning goes away. Does the APC have to be 0?
    Jan 2013
    474
    I checked the clamps, everything is fine, the turret turns. B Axis APC DOES 1, it says the battery is deadwithn and asks for a reference, but I just changed the battery, when I set 0, this warning goes away. Does the APC have to be 0?
    How do you set turret bore to X0 ? ie. Station 1 tool bore centre line at the spindle centre. Do you have an alignment tool for this, where you sweep the turret tool bore or test bar from the spindle with a dial test indicator?
    So if turret is to be referenced, station 1 at X0 is the place to do it ? X0 is spindle centre line and Z0 the turret face to the spindle face or reference plane.
    Jul 2022
    9
    Does this errorur have something to do with the center setting of the turret?
    My problem is that when the B axis APC is set to 1 in the 1815 parameter, it says that the battery of the b axis is dead, when it is set to 0, this warning is removed and I am positioning the two lines in the turret, I will send you the pictures of all of them today.
    Jul 2022
    9
    Solved
    The problem is not related to the machine. It's all due to the fact that the filter clock was x5 combi meter and we gave it neutral.
    Thank you very much for your help.
  1. Tornado 300 Duplomatic Turret
    By yarpo in forum Colchester Tornado lathes
    Last Post: 06-10-2021, 04:24 PM
  2. Colchester Tornado 220M Fanuc 21iT Turret Reference
    By gsjin in forum Colchester Tornado lathes
    Last Post: 10-02-2019, 09:29 AM
  3. Tornado 100 Turret Overheat
    By Lomach in forum Colchester Tornado lathes
    Last Post: 04-08-2019, 01:09 PM
  4. Replies: 11
    Last Post: 11-01-2012, 10:10 AM
  5. Replies: 10
    Last Post: 05-21-2012, 06:29 PM
