587,196 active members*
2,854 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > tormach toroidal cutter insert radius
Results 1 to 2 of 2
    Nov 2013
    87
    I cant seem to find it online anywhere, but what is the radius of the inserts on a 25mm toroidal cutter?
    I hope this isnt a stupid question and the answer isnt 25mm lol
    Jan 2013
    97
    Re: tormach toroidal cutter insert radius
    Googling the insert part numbers comes up with 10mm diameter for the 25mm cutter. Mitsubishi Materials Web Catalogue | Products Information | Insert for Rotating Tools | RDMX1003M0E
  1. Test cutting with Tormach 17mm insert end mill
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 04-10-2013, 05:43 PM
  2. tormach modular insert endmills
    By urbanimports02 in forum Novakon
    Last Post: 12-13-2012, 08:54 PM
  3. insert for a 0.005 max inside radius
    By dingo0722 in forum MetalWork Discussion
    Last Post: 02-27-2011, 04:30 AM
  4. 1-1/2 ball end insert cutter
    By katsbobo in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-30-2008, 03:23 AM
  5. Radius breaking off threading insert!
    By northernmach in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2006, 04:27 PM
