587,925 active members*
3,864 visitors online*
    May 2015
    31
    Lightbulb Tormach Post Processor Failing to Post
    I recently received a Tormach 440, and I am having a difficult time post processing through the latest version of Fusion 360 on a Mac machine running the latest version of OS X. The post processor version that is not working for me is: Tormach_PathPilot_Mill_20160408.cps. I downloaded this post directly from Tormach. I know that I must be overlooking something simple, but for the life of me I haven't been able to figure it out. What I do know is that when I go to the "Generic Posts" drop down menu and select the Generic Haas post processor Fusion 360 will generate G-Code. Under the "Generic Post" dropdown menu the Tormach post processor does not show up as an option. I have placed "Tormach_PathPilot_Mill_20160408.cps" under the "Personal Post" and under "My Cloud Post" on A360 Drive, and it will not post from neither of those areas. I also went to the Autodesk CAM Post Processor page and downloaded the latest Tormach post processor from there and placed it under both the "Personal Post" and under "My Cloud Post" sections, and again I could not get it to post.
    Error: Failed to invoke function 'onSection'.
    Error: Failed to invoke 'onSection' in the post configuration.
    Error: Failed to execute configuration.
    Stop time: Thu May 5 17:10:46 2016
    Post processing failed.
    I also attached a screen shot showing the failed post file.
    I'm not new to Fusion 360 or CNC. I have never had an issue like this before. I am sure that it is probably something simple that I am overlooking since there are others running Fusion 360 on Macs utilizing the Tormach post processor.
    Jul 2004
    81
    Re: Tormach Post Processor Failing to Post
    The important error is "Invalid coolant mode". One of the operations that you are posting probably has a coolant mode that's not supported by Tormach but that is supported by Haas. I think only Mist and Flood will work.
    Attachment 319262
    May 2015
    31
    Lightbulb SOLVED: Re: Tormach Post Processor Failing to Post
    Hey, I really appreciate the help, and that was exactly it! I had selected "Air" since I was going to use the Fog Buster to simply blow air vice coolant. I went back into the tool library and changed the coolant to "mist" and that fixed everything!
    I owe you!
  1. HELP I need Featurecam post processor for tormach
    By nav39 in forum Tormach Personal CNC Mill
    Last Post: 06-01-2013, 10:42 PM
  2. post processor for tormach 1100 for xr3
    By hprose in forum OneCNC
    Last Post: 03-06-2012, 02:55 AM
  3. Which Post Processor for the Tormach CNC Mill?
    By Willyb in forum BobCad-Cam
    Last Post: 10-22-2010, 07:11 PM
  4. Post Processor for Mastercam and Tormach
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 08-23-2010, 07:19 PM
  5. Tormach / Bobcad v21 post processor?????
    By highspeedmazak in forum Tormach Personal CNC Mill
    Last Post: 07-27-2008, 09:44 PM
