Originally Posted by
SCzEngrgGroup
There are SOOOOOO many things other than the quality of the ballscrew (not leadscrew....) that define the actual, real-world accuracy of any CNC machine. Picking out a single component, and making projections of the entire machines accuracy based on that borders on ridiculous. Have you considered that even thermal expansion is often as large a factor as ballscrew accuracy? Or, even more important, the machines ridigity? Backlash/stiction will also typically be major contributors to error.
The reality is, expecting to get TRUE accuracy and precision of greater than, at best, +/-0.002" from ANY machine in this class is wishful thinking. You may do it on a given day, but to do it repeatably, day in, day out, you better get ready to spend a LOT more money.
Besides, it you're making worm gears, you want a lathe not a mill. A mill will limit you to making only very short worm gears, and seriously limit your choices in the tooth profile, unless you're equipped to grind custom cutting tools...
Regards,
Ray L.
