587,098 active members*
5,827 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 1100 S3 using Tormach 1.5" face mill....
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Nov 2007
    2151
    Re: Tormach 1100 S3 using Tormach 1.5" face mill....
    Quote Originally Posted by MikeC8 View Post
    nycnc just did a video recently on a shear-hog facemill single insert cutter, the MRR was impressive. Being a single insert, you can keep your RPMS up where your Tormach is happy, and push it pretty hard.
    Shear-Hogs (Shank Style)
    - - - Updated - - -
    That was a nifty demo!
    I didn't see what was holding it. If not in a tts holder it adds more steps to set height. He didn't detail this that I seen anyway.
    And not something that could go into a atc unless you put that puppy in a tts er32 collet holder.
  2. #22
    Jul 2004
    1424
    Pretty cool.
    And then I went to their website...
    Pretty cool, but not $200 cool....
    ... not something that could go into a atc unless you put that puppy in a tts er32 collet holder.
    You can get it with a 3/4" shank, and than use the TTS adaptor that Tormach sells:
    32432 - TTS Tool Conversion Kit
    I used one of these on a JT3 arbor for my 1/2" Jacob Chuck, since Tormach (for some unknown reason) doesn't sell that size. Worked pretty good. I froze the arbor, heated the ring to 130º, and pressed it together with my shop press.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  3. #23
    On the tormach 4 flute face mill I run mostly 1 to 1.25 WOC and .05 to .075 DOC @ 2500 / 25 IPM and I get really nice results.
    Donald
  4. #24
    Nov 2007
    2151
    Quote Originally Posted by tmarks11 View Post
    Pretty cool.
    That's a very cool solution, I never noticed this on their website.
    I was thinking same thing pretty expensive , but if you need to machine a lot of material then I would look at such tools. That brings to mind the reason I don't have such high performance tools I made a tool makers vice the other day with half dozen different parts and I can say no way the machine cut 50% of the total material volume he cut in a minute and I made a tool makers vice with custom set of soft jaws even . Don't know how others get material but its not cheap around here and I live by a steel mill .
  5. #25
    Jul 2004
    1424
    Quote Originally Posted by dneisler View Post
    Gwizard:
    .125" DOC
    1.000" EWOC
    1296 RPM
    10.262 IPM
    Quote Originally Posted by Steve Seebold View Post
    I have watched the depth of cut and feed rates people have posted that they got from GWizard, and they look to me like they would work quite well. IF YOU WERE WORKING ON A 20 HORSEPOWER MACHINE
    Time to go back to the basics. We don't need a fancy calculator for this:
    MRR= W X H X F
    W = Width of cut
    H = Depth of cut
    F = Feed in inches per minute
    HP = UHP X MRR
    UHP = Unit HP (taken off chart)
    MRR = Material Removal Rate
    Aluminum .25
    Steel 1.4-2.5
    Alloys 2.0-3.3
    so...
    MRR=(0.125" DOC)*(1.000" EWC)*(10.262 IPM) = 1.28 cu in/min
    HP = UHP X MRR = 0.25*1.28 = 0.32 HP
    What was that you said again, Steve?
    ok....now if he was cutting steel, this wouldn't work so well. And his choice of rpm (1300 rpm) does lead one to the natural conclusion he is cutting steel, so I guess I should cut you some slack... he didn't mention Aluminum until after your post, after all.
    If this were a 20HP machine, it would be more like 400 ipm (although his choice of rpm and feed rate are less than optimum, and their DOC would be 2x+ his choice).
    But, like everyone else said, why are you cutting so slow? Lets do some "classic" calculations:
    speed = sfm * 4 / D = 800 * 4 / 1.5 = 2100 rpm
    s = 800 fpm for Aluminum with carbide
    D = tool diameter = 1.5"
    feed = speed * CL * N = (2100 rpm) * (0.005"/tooth) * (3 flutes) = 32 ipm
    CL = Chip Load (recommended by facemill manufacturer), lets assume 0.005"/tooth
    N = # of flutes (I am guessing3 flutes, but YMMV)
    Now lets work the HP formula backwards to find DOC (I based it on 0.75 HP to give you some power in reserve, with 1" WOC)
    MRR = HP / UHP = 0.75 HP / 0.25 = 3 cu in/min
    DOC = MRR / (W * F) = (3 cu in/min) / (1" * 32 ipm) = 0.0.093"
    Same formulas that have been used for years, even before this new-fangled NC thing... Anyone want to post what gWizard says?
    If I was just winging it, I probably would have dialed in 3000 rpm, 0.050" DOC, 1/2-2/3 step over per pass, 40 ipm. Increase DOC based upon sound/cutting load.
    Tim
Page 2 of 2 12
  1. Replies: 18
    Last Post: 09-23-2015, 06:49 AM
  2. New Tormach 1100 series 3 vs. Old Tormach 1100 series 1 to purchase
    By inventor1227 in forum Tormach Personal CNC Mill
    Last Post: 03-21-2012, 09:55 PM
  3. Tormach PCNC 1100 VS. SmithyCNC 1240 Bed Mill... Which one and Why?
    By segal.arye in forum Uncategorised MetalWorking Machines
    Last Post: 11-30-2010, 07:03 PM
  4. Tormach PCNC 1100 VS. SmithyCNC 1240 Bed Mill... Which one and Why?
    By segal.arye in forum Tormach Personal CNC Mill
    Last Post: 07-20-2010, 12:14 PM
  5. Replies: 2
    Last Post: 07-20-2010, 11:48 AM
