587,887 active members*
3,190 visitors online*
Results 1 to 2 of 2
    Jul 2009
    14
    Toolpath generation problem
ID:	242418When i try to generate a toolpath ( outside/right) for the outline (please look at the attached drawing). I get this error: No toolpath generated for current parameters. Check Tool can fit into selected vectors at machining parts.
    If i select "On" there is no problems.
    Generating toolpath for holes ( inside/left) is not a problem.
    Any idear why Vcarve pro 6.504 dosent like this drawing?
    Best regards
    Poul Munch Andersen
    Nb. The file upload program dosent like crv files. So you need to change the txt to crv.
    May 2007
    9
    Re: Toolpath generation problem
    The outline is an open vector not a closed vector. On the right hand side part of the span overlaps the rest of it. Remove that span and close the vector then you can create the toolpath no problems.
  1. 3D Toolpath Problem
    By kolias in forum Mastercam
    Last Post: 03-22-2014, 04:31 PM
  2. Toolpath problem
    By sweetwood in forum Mastercam
    Last Post: 07-14-2010, 06:35 PM
  3. toolpath problem
    By Nicovm in forum Jewelry Design Software
    Last Post: 09-02-2008, 07:39 PM
  4. Help toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-18-2008, 02:03 AM
  5. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
