403 Forbidden
Need help deciding which bit to use for your next routing project? Our experts are waiting to help! Here at CNC Router Store, we provide expert advice on which tools you need to get the results you want.
Happy 1st of August everyone! This summer has been flying by and we just want to thank all of our customers for their questions and feedback! This week, our customer called in to inquire about a bit to cut foam. The foam was being used for a decorative point of sale sign and needed to be cut accurately. This foam was also approximately 3” thick and the bit needed to cut through its entirety.
We recommended the Onsrud 52-550 series, specifically sku numbers 52-570 and 52-574. These bits are solid carbide, upcut, double-fluted bits. They are specific foam cutters for thick material and create and upward chip flow.
Don’t forget to check out our new feed rate calculator on cncrouterstore.ca to ensure that your parameters are set just right for the results you want.
If you felt this was helpful, or have any inquiries of your own, please contact us with your questions and feedback!
Click here to order your own from the Onsrud 52-550 series!
Attachment 244218
