587,245 active members*
3,168 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tool rack design for 1100 Enclosure
Page 1 of 2 12
Results 1 to 20 of 26
    Mar 2015
    178
    I know there are several nice variations of ideas on Tormach tool storage out there but I put my own little design together using a few custom brackets I made and some 39" shelf standards from the Big box store. The easy way would have been to screw the standards directly to the enclosure but I wanted something that did not require drilling or modifying the enclosure in any way so when removed there is no sign it was ever there. Brackets attach using existing enclosure screws. I slotted the holes and made them a bit larger to allow for adjustment and measurement errors on my part. My other goal was to have it be very flexible in terms of shelf spacing and also to be able to make various versions of the shelves depending on the tools. The side brackets are laser cut 16 ga 430 SS and designed to fit standard 3-1/2" and 5-1/2" x 3/4" S4S pine lumber. I reverse engineered the store bought bracket hooks profile to work on the standards. Some folks say wood is no good for the tools (corrosion?) but I've never had any problems. I suppose hdpe or nylon could be used but I figured pine was cheap and good enough. Next step is to cut to length and machine the hole patterns into a few shelves. Very bottom bracket designed no angle shelf for calipers or misc. heres some photos progress so far
    Attachment 357006
    Attachment 357008
    Attachment 357010
    Attachment 357012
    Jun 2014
    1780
    Re: Tool rack design for 1100 Enclosure
    Quote Originally Posted by Paul-JB View Post
    Attachment 357006
    Attachment 357008
    Attachment 357010
    Attachment 357012
    Looks good Paul!
    I use pine for tool holders as well with no problems, I do soak them good with some motor oil or equivalent before use though.
    mike sr
    Mar 2015
    178
    Made one shelf and slapped a few tools on to test it. I'm thinking its going to work out good.
    Attachment 357024
    Dec 2013
    5714
    I like it :cheers:
    Jun 2006
    3063
    Great idea!
    Aug 2015
    368
    Super clean!
    Dec 2003
    673
    Attachment 357024
    Nice!
    Mar 2013
    131
    Quote Originally Posted by Spinnetti View Post
    Nice!
    I was thinking of something similar for the wall right next to my machine. I will space the holes a little farther and make a few changes still. I am designing a ton of shelves I'll be cutting on aClick image for larger version.
Name:	tool holder.jpg
ID:	357324 cnc router soon.
    Mar 2015
    178
    That looks good too! I like the hooks are those an extrusion profile??
    One thing I noticed right away on mine was that having multiple rows could be problematic in that reaching over front row tools to grab ones in back could cause cuts or pokes to your hands, wrists etc from taller tools in front. Organizing tools large in back would work but invariably we know things end up jumbled around.
    The other thing I considered was maybe this won't be a place to store ALL my tools. Just the most common ones or for a particular job. May have to make a couple single row brackets for 1-1/2" to try.
    Mar 2013
    131
    Its a shape I saw on some extruded aluminum supplier that I had modeled last year for something else.
    I was going to add shelves coming down and put an aluminum sheet metal plate slightly tilted back for any dripping coolant to fall.
    I have a few walls I am designing shelves and such for. Once I got this machine in my garage, I had to change my whole approach since I rarely touch the Bridgeport any more. Like putting a desk and computer in there. I will post pictures of the shelves and other holders as I design and make them. I have access to a 4x8 shopbot so making these is a cinch once they are designed.
    Nov 2007
    2151
    Quote Originally Posted by eltejano View Post
    I look around on internet and I see some amazing shops. Everyone is different and has different needs. I like to keep shelving in garage/ shop at just above shoulder height and go up from there. leaves room below for roll around tool boxes, and other stuff to go against wall. I kind of go by the workstation concept. Always fun to see how people arrange their work spaces and how they change over time.
    here are a few pictures on my work areas and tool storage racks.
    I use simple 12 tool per rack in a 3 x 4 layout they don't get to heavy they set on workstation top or they also slide into shelf racks above that area.
    Attachment 357452
    I make custom racks for just about everything.
    Different collet racks.
    Attachment 357454
    Attachment 357456
    Even little for little tools like bit drivers
    Attachment 357458
    Of course you need mood lighting I put led task lights on each roll around tool box / workstation.
    Attachment 357460
    My shop is very small so I cram tools into every spot i can find.
    Attachment 357462
    My shop is always changing. fun to look back at old pics and how it looks now.
    Mar 2015
    178
    Looks like a nice setup there surrounded by "command central" with all the stuff you need to work in reach.
    Putting the tormach monitor and peripherals on the roll cart is something I thought of but never followed thru on. Having it on the swing arm from tormach isn't bad but sometimes it would be nice to be able to move completely out of the way. Agree keeping the floor space around the machine clear or quickly accessible is key. Especially in the case like yours in a garage where moving things around could be a necessity.
    Curious where you procure the acrylic and did you need to buy a full 4x8?
    Jun 2006
    3063
    I made this little tool caddy that hangs off the chip tray on my enclosure-less 1100. It holds 10 tools and can be located within arm's reach of the spindle. 10 tools is enough for all of my jobs so far and it makes for a nice manual tool changer carousel.
    Attachment 357504
    Apr 2013
    1788
    I did sometime similar but put the small tool holder at the right end of my 770 table. Material is a plastic cutting board from Wally Mart.
    Nov 2007
    2151
    Acrylic depending on grade and thickness can be expensive.
    There are a number of places. brands and grades can vary widely. I use Chemcast brand and buy mostly large amounts. Best price for easy ship acrylic material is freckleface.com. They have all sizes from 1x1 to 4x8. from 1/8 to 1" thick. funny name but I have purchased many sheets from them.
    Hope this helps.
    Mar 2015
    178
    Thanks I will check it out. I know McMaster sells it but probably very expensive.
    Jul 2007
    1602
    Paul, if there is a kitchen counter place nearby, see if they will sell you some Corian drops. It machines nicely.
    bob
    Oct 2010
    670
    Here's how I did it. Super simple, movable and adjustable. I'm now on my second drawer full.
    Attachment 358270Attachment 358272Click image for larger version.
    The Body Armor Dude - Andrew
    Nov 2007
    2151
    I see all these big racks and stand up workstations in big shop areas!.
    I work in small slot with everything right there. All I do is pre cut a pile of stock for the parts I plan to make and set in tray on or next to fixture table -tool box on right. That is where I fixture all stock and set and measure tool offsets and machining results. All tools used in programs I place in order along the bottom row of all those trays where the control puck, keyboard and PP display is stationed . foot pedal is on floor between that and pcnc1100 on left. With convenient air for blowing of chips and brushes I can and did set and make all the parts in the below picture with out standing up once lazy im besides my left foot has been hurting for a while now. Tv is on exact same monitor pivot mounted on the other side of shop. I can turn around and watch tv while long machine ops are going or fixture more material in extra fixtures and collets.
    Easy simple its even at eye level so setting offsets is fast. Edit: With path pilot these days and using a 5c collet system You can make piles of small parts. Just turn on machine home it. midi g01 f50 x0 y0 witch is g54 in preset offset page and centered over 5c collet in vice. Then I just set to tool #9 a 1/2 carbide endmill. load program midi m3 run cutter down to stock. touch it mill off top and zero z. m5 run up look at program load first tool on bottom of rack. and run. I dont even use the expensive Hamier probe on the rack or jog around and find anything. easy fast in my case. Just a method I use everyone works differently. Simple enough that I can get up and make a part anytime I want to in very little time
    Attachment 358318
    Simple parts
    Attachment 358320
    Having big work spaces is not always that better.
    Attachment 358322
    I noted in another thread about rubber floor mats they were for the rest of my shop
    Nov 2005
    201
    Very nice set-up
    what kind of vise are those?
    Attachment 358318
    Simple parts
    Attachment 358320
    Attachment 358322
Page 1 of 2 12
  1. Custom 1100 stand and enclosure
    By Trickle X in forum Tormach Personal CNC Mill
    Last Post: 01-17-2017, 03:34 AM
  2. New Tormach 1100 Enclosure
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 02-13-2015, 05:42 PM
  3. Tormach Enclosure, PCNC 1100
    By jeremyk409 in forum Tormach Personal CNC Mill
    Last Post: 01-08-2014, 12:09 AM
  4. How to cut a rack on a PCNC 1100?
    By CNC-Dude in forum Tormach Personal CNC Mill
    Last Post: 05-20-2011, 09:31 AM
