Hello
I work at a shop where we have a old presetter (1986) that we use to measure the tools for the mills. It works ok but to set the Dia. of a twin bore with in .001" is a pain in the neck. It's got a scope with 20x magiftion and it shines a light on the tool and you look at the shadow through the window to gague the tool. The image is not supper clear and if you put your hand on the "scope arm" you can see the image .001 or so. I was wondering if this is typical with presetters of this type and what are the new presetter like?
Thanks!:rainfro:
