Hello,
I am having an issue with UCCNC after loading a tool path saved from VCarve. When I save from VCarve, everything looks as I'd like. However after loading the file into UCCNC, the tool path position in the preview is not accurate. My test job is a piece of square material with a square pocket cut directly out of the center. UCCNC shows the pocket in the top right of the work space. I have attached screenshots of both. I am very new to this, so please let me know if there is additional information I need to provide to explain the issue I am experiencing better, or if you have any ideas that would help me get back in the right track. Any help is appreciated!!
Thank you in advance.
Machine: Stepcraft 840
Tool path file type: Mach 2/3 Arcs (mm) (*.txt)
