587,793 active members*
3,484 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tool nose comp for Fanuc OT?
    Jul 2007
    17
    How do you set toolnose comp for a boring bar? In the Geometry page I use 3 under the "T" and use .0156 uner the "R" for an O.D. turning tool with G42 and G40 to cancel in the program.But what do you use for a I.D. tool?
    Aug 2007
    31
    use a G41 in the program instead of G42, and a 2 in the T
    Dec 2009
    1
    Hi I'm having comp problems myself. I haven't never used it on my fanuc OT and trying to go by the manual. Maybe I'm to small minded but I've been trying to get it to work properly for a week now and I've even contacted fanuc and they act like it should be working. You say you've been od turning using the direction 3 under "T" . So have I also under "R" .016. It seems like my machine is loosing position. May be I'm not putting My
    G42 in correct place. Do you have a sample program I can see?
  1. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  2. Fanuc 11m Tool Comp
    By Jfrahm in forum Fanuc
    Last Post: 07-29-2007, 11:01 PM
  3. Fanuc 16T tool nose comp question
    By dmcool in forum Fanuc
    Last Post: 07-23-2007, 05:21 PM
  4. Fanuc 5T Tool Nose Compensation
    By John3 in forum Fanuc
    Last Post: 07-16-2007, 04:58 AM
  5. tool nose comp.?
    By pp-TG in forum MetalWork Discussion
    Last Post: 09-19-2006, 09:36 PM
