Hi, this seems a great forum, with some very helpful people. Just shows that most/some, of us world citizens, are nice folk.
We are retrofitting our Cincinnati machining centre, with a 24 tool carousel. Setting tool changing has not been a problem and it takes the shortest route to get tools. It's been a long project and we have only spent the time we could afford on it, rather than full on until working. It seems now just about done, but I am struggling with the logic of setting the position of the part and the tool height. To experiment, I have set a few tools to a given height off the table and these values are going into the tool height set box OK. I have then set an imaginary X, Y, Z zero position, using the preset buttons. By experiment with simple programs, changing the tool number in the same program, it seems that when I get a tool using the T? M06 command, it automatically applies the tool height compensation. Question 1, as such why is there a G43 H?, in programs generated in the fanuc processor? The next Question, is what is the best logic to use for part set up. Fanuc calls for a G54, but the preset buttons only seem to set the read out to zero, they do not set these into G54, should they? Also I am getting various results pressing the Z preset, the first time it went to zero. A second time after running a program with a Z-50. command in, the preset button put in a -50. and another time something else came up. I am really stuck for some sort of logic to apply to this. Could someone please give me an example of how best to approach this? Do I use G43 and G54, or use the atomatic compensation with M06 and the preset buttons?
All help and ideas will be much appreciated, Regards, Colin
