Tool diameter/ipm/plunge rate/etc question.
Guys as usual i have another question... The thing is I'm finally starting to learn a little more about SheetCAM... Thanks to you al,l and Bubba Has been a great help!! I need to know how you guys determine the proper tool size per application and the proper feed/plunge rate? The thing is when i seupt the program for a bracket, no holes.. The program filled in all them fields all by it's self... Is this correct.. Or did it just load the same setting that was loaded in the prior program.. It just don't sound right to me.. If the software can set all the tool setting by it's self then it could surely cut a part with various holes in it from a single layer as well...
Is there a link with all the tool diameters and rates by chance?
Stoney
http://www.quarterscaleprostreetberetta.com/
