587,434 active members*
3,244 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > TOOL ARM NOT FULLY ROTATING!! HELP!!
Results 1 to 12 of 12
    Feb 2012
    19
    Help!!! I have a VF3SS and have a problem with the side mounted tool changer tool arm during a tool change. Its rotating half way and then stopping, Ive tried putting in a heavy tool to try and stop it but makes no difference. Please help!!!
    Apr 2005
    713
    What alarms do you get?
    Feb 2012
    19
    Quote Originally Posted by Matt@RFR View Post
    no alarms, just sticks when trying to do a tool change, could it be the cambox or servo amp??
    Apr 2005
    713
    I'm no tech, just trying to get the ball rolling for you. Someone should be along shortly that knows a helluva lot more than I do.
    Does the arm work normally at 5% rapid? 25? 50 or 100%?
    It strikes me as odd that you don't get alarms. Does the cycle simply stall infinitely?
    Feb 2012
    19
    it happens at any rapid, my worker txt me earlier as im out of the country at the moment, just said when doing a tool change the arm stops mid way through and we have todo the recovery process??
    Dec 2008
    717
    It should be giving some sort of alarm...but shy of that I'd say your guy may not be telling you everything that happened:nono:
    I've NEVER had my arm stop half way FWIW - 2006 VF3SS
    Tim
    Feb 2012
    19
    Quote Originally Posted by WallyL7 View Post
    i know! it must be showing an alarm! i hope its not the cambox
    Feb 2012
    0
    With no alarm mentioned its hard to understand whats going on. Have your operator call the number on the machine for help. A technition can usually help step through the problem to find the cause or get it working again.
    Feb 2012
    19
    sorted, there was oil leaking from the bottom of the cambox, so no oil in the cambox! just need a new bearing cap to stop the leak
    Feb 2012
    0
    Nice. Got to check fluids once in awhile if a leak is seen. Just make sure the correct oil is used after that seal is replaced. Dont want any other mishaps.
    Feb 2010
    1184
    Quote Originally Posted by deadjam View Post
    And fresh oil I hope!?
    Feb 2012
    19
    Quote Originally Posted by haastec View Post
    oh yeah!!!
    filled the cambox with oil, fitted new bearing cap, all fine until after a few tool changes we get the alarm 673 - TT SERVO ERROR TOO LARGE.
    any help much appreciated
  1. who sells fully supported rails?
    By SatanKlawz in forum Linear and Rotary Motion
    Last Post: 06-20-2012, 09:06 PM
  2. Tool magazine not rotating backward
    By mcv300 in forum Sharp CNC
    Last Post: 05-06-2011, 01:07 AM
  3. Partner 1 Tool Changer not rotating
    By Quadin in forum Milltronics
    Last Post: 01-15-2008, 03:23 PM
