Hi everyone!
I've got a Chinese bought TS3040C-H80 machine with one of those flexible shafts to a router hanging above the machine, and just a spindle and chuck on the Z axis.
And like another post on the forum here, I've probably overloaded the chuck causing it to fall out of the spindle, so I'm wanting to replace the whole thing with a Kress FME800 or similar spindle if possible. (I've already ordered the Kress as I'll use it for a DIY build if unable to make use of it here).
The new spindle weighs 1.4kg, this is my main concern, and the offset of the weight. I've seen the same basic machine with a directly mounted spindle and the only difference is that some has a 12mm instead of the 10mm round linear bearings like I have, and that the Z motor is directly coupled to the screw instead of belt driven as in my case. Unless I get really creative the center of the tool will be 23mm further away from the X axis, lost Y work space is not a concern, but maybe the shifted extra weight?
I've tried to add 1,2kg to the Z axis and it didn't seem to care at all, but still, to start off with; if this is an insanely bad idea - please stop me now
Meanwhile I'll continue drawing up my two suggestions for a mounting bracket and upload for input later.
input will be much appreciated!
Bjorn
