587,762 active members*
3,416 visitors online*
Results 1 to 11 of 11
    May 2009
    71
    TNC screen / tube replacement
    Bridgeport Interact 720 VMC
    Heidenhain TNC 2500 control
    Fanuc drives (red cap motors)
    I think my screen is going out, it's been getting really bright on the right hand side when I first turn it on, more than it usually does. When I turn down the dimmer all the way it is also very bright on the right hand side and black on the left. It's also been showing squiggly / jittery text when the machine is first powered up. Once it warms up it is ok (like in the pic), and I can adjust the brightness to get it clear.
    Has anyone found a replacement tube that will work, or tried installing an LCD screen? I have 2 ancient laptops that would be perfect donors if it's possible. I remember reading a thread about this awhile back but cannot find it. Thanks guys
    May 2009
    71
    I guess the picture was too big the first try, here it is.
    Aug 2010
    0
    FLjoyride Hello, I have two Interact 412 with Heidenhain TNC 151, one monitor stopped working and could not be repaired and put one video converter of Chinese origin and a lcd with this solves the problem. This converter has outputs for VGA monitor and you can even put any TV with RCA connections. is the make and model GBS8219 Gombes, I hope my experience will serve you.
    Sep 2005
    250
    Search this company's website, I know they have one that will work with your machine because I have seen them on ebay.
    I have a Bridgeport 412 that the screen has been doing the same thing as your for over 10 years now. It just has to warm up.
    Keep your eyes out on Ebay, I see the monitors for sale once in a while.
    Sep 2005
    250
    May 2009
    71
    OK, I'll just wait for it to go out completely I guess. Thanks for the replies I'll keep in mind the LCD option as well.
    Jan 2005
    1121
    mod-mec:
    a specific manufacturer and product would be very helpful if you have done this
    A heidenhain is not an ez trak
    Aug 2010
    0
    Heidenhain BE211 reemplazo del monitor. - spanish.alibaba.com
    Works without problems, leave the machine ready in 15 minutes.
    In my case, buy the converter and a 12 "LCD is not how to upload pictures but I have some work done.
    Aug 2010
    0
    These images are from time proved the lcd, there is also an option in Europe to a company called "tsubis" but it was wasteful but is much simpler to replace.
    May 2009
    71
    Wow that looks great.
    Sep 2005
    250
    Quote Originally Posted by gus View Post
    mod-mec:
    Gus, I was just showing him a seller on ebay that sells replacement monitors. They make them for the Heidenhain monitors.
  1. replacement laser tube
    By Gary123xyz in forum Engraving Machines
    Last Post: 07-30-2011, 12:18 PM
  2. Z-axis oil tube broke - need to identify and source replacement
    By torinwalker in forum Maintenance DIY Discussion
    Last Post: 02-10-2011, 07:10 PM
  3. Screen replacement
    By cincinnatimachine in forum EDM Discussion General Topics
    Last Post: 12-21-2010, 11:39 PM
  4. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
  5. EZ-Track Mills LCD Screen Replacement Kits
    By RADAPG1 in forum News Announcements
    Last Post: 03-20-2008, 03:51 AM
