587,092 active members*
3,003 visitors online*
    Nov 2007
    27
    TM 1 - service
    I have a 2000 TM 1 which has run flawless since purchase and I'm just starting to experience some small issues with, which I can live with. I have kept machine clean and lubed since day one. Is there any other service that I need to be doing, or any maintanence procedures that I should look into before I have some major issues. (ex. backlash adj. , way wipers replaced )
    Any suggestions would be appreciated.
    Feb 2007
    498
    the only thing that i do is when i clean the machine i wipe the linear guide ways clean,and i always try to keep chips from building up on them,the most important is lube
    grease is cheap,thats my moto
    Sep 2006
    251
    f1jdm,
    Keep all of your axial fans clean and make sure that thay are running. Heat is the # ONE problem with electronic failures.
    Just a good ol' boy, never meanin' no harm.
    Joe
  1. Great Service!!!!
    By Smitty911 in forum Complaints and Praise Discussions
    Last Post: 02-05-2008, 11:05 PM
  2. IH in Commercial Service
    By bumperscoot in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2007, 09:00 PM
  3. provide CAM service.
    By eivendai in forum Employment Opportunity
    Last Post: 04-15-2006, 03:17 PM
  4. Discovery 300 needs service in WI
    By scnolan14 in forum Bridgeport / Hardinge Mills
    Last Post: 02-22-2006, 07:44 PM
