587,829 active members*
2,817 visitors online*
Results 1 to 6 of 6
    Apr 2012
    79
    tk to axis doesnt work
    Hi
    I have configured my machine and have always used the tklinuxcnc screen and everything works fine. I now want to change and use axis so I can tune the servos easier but when i change the machine does not come out of estop mode. All i have done is change the tklinuxcnc to axis in the ini file. Does anyone have any suggestions on what i have missed out.
    Nov 2005
    496
    post your config files.
    Apr 2012
    79
    Hi
    I do not have my files to hand today but i did more work on it yesterday and I believe it is a problem with the e-stop circuit. I do not have a switch on the e-stop input yet and have set it up so that it is always out of e-stop. If i reverse the signal in hal and open linuxcnc the machine immediatly turns on electrically but says it is in e-stop mode and i cant turn the machine on in the software. I am getting confused on this one. Does linuxcnc need to see the external e-stop switch on before it will work? I just dont see how it all works fine with the tk front end but when using axis it is not working.
    Lee
    Apr 2012
    79
    Chester88
    Just been into work and my config files are now attached. Thanks for having a look.
    Lomach
    Attached Files Attached Files
    Nov 2005
    496
    hmm I don't see anything obvious yet.
    You are using a classicladder estop option and you didn't include other config files so i can't check them.
    when you are running linuxcnc open a halmeter and check the estop signals and see whats happening.
    Chris M
    Apr 2012
    79
    Sorted
    Just to say I have sorted it now. For some reason I had to invert the output when using the axis screen and return it to normal when using TKlinuxcnc. Seems strange but it works thats the main thing. Thanks for looking at my configs.
    Lee
  1. my L297 L6203 doesnt work ??
    By lalaabdallah in forum Open Source Controller Boards
    Last Post: 06-16-2013, 11:30 PM
  2. my L297 L6203 doesnt work ?? :(
    Last Post: 01-01-2012, 10:59 AM
  3. my L297 L6203 doesnt work ?? :(
    By lalaabdallah in forum Stepper Motors / Drives
    Last Post: 01-01-2012, 01:53 AM
  4. Replies: 4
    Last Post: 03-25-2011, 12:52 PM
  5. TurboCad 9 Doesnt Work on Vista
    By Mr.Chips in forum Uncategorised CAD Discussion
    Last Post: 09-07-2008, 06:15 AM
