Hello Everyone,
I'm new to the CNCzone (and benchtop milling) and wanted to ask for some advise, if I could. I recently acquired a Harbor Freight 47158 (Sieg X1) in exchange for some carpentry work. My plan is to convert the mill to cnc in the next few months. But before that, I wanted to upgrade and/or improve upon some of the mechanicals first.
Based on research/reading previous posts, I've already ordered/installed the belt-drive conversion kit from the Little Machine Shop. It made a HUGE difference in noise (much quieter) and spindle speed (much faster). Now, in addition to converting to a belt-drive, the prevailing wisdom seems to suggest I should also get a long table kit (x-axis) as well as the extended y-axis upgrade. But there are two different upgrades available for the y-axis, one of which includes a tilting spindle option. I'm wondering if that's a worthwhile option to get or if I should just go with the standard kit.
Does anyone have experience with the tilting option? Is it worth the extra money; ie, is it useful and/or would it be useful once I've switched to cnc?
I'm kind of a green horn with milling in general (I've got a little bit of experience on a lathe and knee mill, but it's limited) ... so any and all advice will be gladly received.
Thanks - Corey
