587,513 active members*
2,823 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Through Spindle coolant on VMC
Results 1 to 4 of 4
    Jul 2007
    378
    Hello
    I was just wondering what Gibbscam (2007) has to offer when It comes to Through Spindle coolant. All I see is Flood coolant. Is it just a post upgrade, or is it more than that?
    Jun 2003
    513
    Quote Originally Posted by glovebox20 View Post
    Hello
    Post update. Post a sample program with comments enabled, mark it up what you want changed (don't edit the original code), then email it to the post department explaining what you want done. They will also update the MDD with your additional coolant choice.
    May 2012
    85
    IF YOU MAKE EITHER A DRILLING OP OR MILLING PROCESS.THEN DOUBLE CLICK ON THE OPERATION # IT WILL OPEN UP AND YOU CAN TYPE IN YOUR THRU SPINDLE COOLANT COMMAND IN THE [AT OP START] WINDOW. FOR MAKINO IT LOOKE LIKE THIS
    "M26 G4 X5.(THROUGH SPINDLE COOLANT)" WHEN YOU POST YOUR PROGRAM IT WILL BE IN PROGRAM AFTER TOOL CHANGE. YOU HAVE TO USE QUOATION MARKS.EVERYTHING INSIDE THEM WILL POST
    Jul 2007
    378
    " IF YOU MAKE EITHER A DRILLING OP OR MILLING PROCESS.THEN DOUBLE CLICK ON THE OPERATION # IT WILL OPEN UP AND YOU CAN TYPE IN YOUR THRU SPINDLE COOLANT COMMAND IN THE [AT OP START] WINDOW. "
    Thanks for the tip, but it looks like my post is not setup to allow this.
    glovebox20
  1. Through spindle coolant
    By godtar in forum Daewoo/Doosan
    Last Post: 07-19-2012, 07:11 PM
  2. Coolant for HF Spindle ?
    By Greolt in forum DIY CNC Router Table Machines
    Last Post: 07-03-2008, 10:59 PM
  3. Thru Spindle Coolant
    By Doubleddaved in forum Haas Mills
    Last Post: 03-25-2008, 12:40 PM
  4. thru the spindle coolant?
    By cnc@52 in forum Haas Mills
    Last Post: 09-16-2007, 06:03 AM
  5. Through Spindle Coolant
    By Josh-PTP in forum Haas Mills
    Last Post: 02-28-2007, 06:42 PM
