587,489 active members*
3,202 visitors online*
Results 1 to 9 of 9
    Nov 2009
    4
    Threadmill problems
    We've started using thread mills to machine threads for ports (ex: SAE J1926/1). The problem we're having is that we're getting a fine hairline strand of metal at the start of the threads. We've been using a razor knife to remove this. Has anyone else had similar problems and/or ideas to eliminate this?
    Let me know if I need to provide more info.
    Any help is greatly appreciated.
    Jan 2010
    34
    I just completed a thread milling job with the same problem . I ran the end chamfer to the maximum of my tolerance and was able to fix the burr issue.Also are you starting at top and going down or bottom and going up?
    Nov 2009
    4
    We start at the top and go down.
    Are you referring to the "L1" dimension (Spotface to angle break depth)?
    Thanks.
    Jan 2010
    34
    IT IS BETER TO START AT THE BOTTOM AND COME UP, ALSO ARE YOU USING CAM SYSTEM OR CONVERSATIONAL PROGRAMMING
    Nov 2009
    4
    CAM system but I believe we used Vardex software to generate thread milling code.
    (Fadal Mill)
    Jan 2010
    34
    I believe you are referring to your tool using L1.I am talking about the actual thread lead chamfer on your part
    Nov 2009
    4
    The L1 I was referring to is part of our port specifications. See: http://www.goodyearrubberproducts.co...n1.Page477.pdf
    Jan 2010
    34
    we are talking same.you have +.015 on your tolerance as you know.that may not be enough to do away with burr.try running from bottom up conventional milling with a couple of light finish cuts
    Mar 2008
    638
    Quote Originally Posted by porter View Post
    Ah yes. I remember doing some aluminum manifolds with multiple ports similar to those. Also threadmilling. You're right about those very fine hairs at the top where there is an incomplete thread.
    It's been a while but I think we put our porting form tool in twice and threadmilled twice in an attempt to get it burr free. (also threadmilled from bottom to top to climb mill). It was better but still had something there to deburr no matter what.
    If you get some method that works, post it here so we all can learn.
  1. CNC Problems
    By WCHScarpentry in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2010, 08:20 PM
  2. Threadmill program
    By cncwhiz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-11-2009, 11:44 PM
  3. X3 - threadmill on live tool
    By cnc-king in forum Mastercam
    Last Post: 10-13-2008, 03:55 PM
  4. How to rough/finish threadmill in MCX?
    By John_B in forum Mastercam
    Last Post: 07-27-2008, 04:25 PM
  5. DNC Problems
    By mt92 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2008, 08:23 AM
