587,362 active members*
3,418 visitors online*
Results 1 to 20 of 20
    Dec 2005
    439
    Thread Milling a Taper
    I am looking to make some manifolds that require a few different NPT threads. ( 1/4, 3/8, 1/2, 1-1/4) I have no problems with NPS but I can't figure out how to mill out a tapered thread. As well I have not looked yet but I do not know the degree of taper for a npt thread. I will be running this threw a Haas control, any suggestions would be appreciated.
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Feb 2008
    267
    I believe the taper is 1.78333Degrees from center.
    Here is a link to Harvey Tool's site that has the tool you need...
    http://www.harveytool.com/products/p...keyword=thread
    Scroll to the bottom.
    I've used them and they work well.
    Good Luck.
    Mar 2006
    153
    A npt thread taper according to the machinist handbook is .75" per foot. Depending on which tool you use it should come with software that will generate the code you need.
    No matter how good you are, there is always someone better!!!
    Feb 2008
    267
    The .75" per Foot is a diametric designation
    i.e. the diameter is tapered .75" per 12." of length.
    Which in turn work out to be around 1.789 from center.
    Mar 2006
    153
    Alot depends on the cutter I thread mill ALOT of pipe threads NPS and NPT. I have a 4"-8 NPT that I use a single point thread mill on it has a special G code that it runs so that it can spiral down to make the taper. I then have a 1.5-11.5 NPT that uses same path as my 1.5-11.5 NPS we just change out the multi tooth insert because the insert has the taper angle on it. There is alot of factors to look at to awnser your question.
    Jun 2007
    3734
    Talking Simple cheat.
    Do on a 4th axis rotary table (if you have one) tilted to the desired angle.
    If you have a tiltable head like my SX3 then you can cheat with the helix angle too. Then just use a lathe insert to do the cutting.
    Dec 2005
    439
    Ok so this will not be a simple as I had hoped. I have no 4th axis so that ones out, I'm coding by hand so software is out. A macro maybe?
    ProProcess I like those tools that maybe the route I need to go, I have a single point threading tool and I was hopping to use it.
    HAAS GR-408
    Mar 2006
    153
    I have a threadmilling macro laying around some where let me find it and I'll send it to you.
    Jul 2003
    1220
    automizer
    Attached is a program I have written. This may help.
    Attached Files Attached Files
    2932
    download a demo of machinist toolbox
    it has simple cnc functions
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Dec 2005
    439
    Well Now I have some options to try
    dertsap I downloaded the demo of machinist toolbox a long time ago and have not touched it maybe I should dig it out.
    dcoupar Have you used this software?
    Kiwi that is a cool program, what made you write it?
    chrisryn if you could find that I would love to play around with it.
    HAAS GR-408
    Mar 2006
    153
    Quote Originally Posted by automizer View Post
    I use vardex on alot of my threadmilling. They seem to be the only ones that have the type of NPS thread mills I need. There software is a timesaver. Works 99% of the time. Just keep in mind that it usually outputs the threadmill pass in incremental, not absolute.
    Jul 2003
    1220
    ........ I have a single point threading tool and I was hopping to use it.
    Quote Originally Posted by chrisryn View Post
    I use vardex on alot of my threadmilling. They seem to be the only ones that have the type of NPS thread mills I need.......
    All I could find was code for their multi point cutters.
    Do they have code for tapered thread using single point cutter?
    Mar 2006
    153
    hmmm I know I got my code some were let me look at the software I have and see. I am still looking for that macro I had.
    Dec 2005
    439
    I just got a Vardex catalog today im curious what tool holder you use? and what inserts you use?
    HAAS GR-408
    Apr 2008
    43
    use their software (you can download it from their site). the program will recommend you the right tool.
    if you mill larger diameters try their shell mills.
    Mar 2006
    153
    For NPS
    Holder :TMC100-5
    Insert: 5EI11.5NPSTM2
    For NPT
    Holder: TMC125-5
    Insert: 5EI11.5NPTTM
    VBX grade on both inserts
    This grade works well on cast iron and cast aluminum
    Jul 2003
    1220
    Question
    For NPS
    Holder :TMC100-5
    For NPT
    Holder: TMC125-5
    Insert: 5EI11.5NPTTM........
    I couldn't find these holders and inserts in the Vardex catalogue.
    What threads are they used for?
    Dec 2005
    439
    Quote Originally Posted by Kiwi View Post
    if you have the paper catalogue the holders are on page 229
    the inserts are on page 216
    I see in the catalogue there is a holder just for NPT there TMN Holder
    HAAS GR-408
  1. taper thread cutting
    By cncmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2008, 10:59 AM
  2. thread milling
    By fourperf in forum Fadal
    Last Post: 11-21-2007, 04:32 AM
  3. Milling a thread,
    By CharlieM in forum G-Code Programing
    Last Post: 10-09-2007, 09:05 PM
  4. taper thread
    By gcrandall in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 04:13 PM
  5. thread milling
    By DavidC1949 in forum G-Code Programing
    Last Post: 03-30-2006, 07:27 PM
