587,518 active members*
3,331 visitors online*
Results 1 to 2 of 2
    May 2011
    0
    thread milling mazatrol
    Hi, Can anyone assist with a thread milling example program for putting threaded holes on a pcd on the face of a part, Machine is an integrex 640MT PRO
    I would like to use Mazatrol if possible? eg 150 mm pcd with 8 off equally spaced 12mm thread with 1.75mm pitch
    May 2011
    0
    Its ok thanks, now sorted using "Circ Mill" option 1 for "Tornado" Set pitch 1 to zero & set pitch 2 to the pitch ie 1.75mm, Set dia to the major of tap = 12mm
  1. drilling and thread M16 Bobcam and Mazatrol M-2
    By sve0019 in forum Uncategorised CAM Discussion
    Last Post: 10-13-2010, 05:27 PM
  2. mazatrol thread milling
    By cr500 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2009, 02:48 PM
  3. thread milling in nexus using mazatrol
    By uperez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2009, 09:06 PM
  4. Mazatrol variable thread lead?
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2008, 07:24 PM
  5. Mazatrol T Plus thread cycle in synch?
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 04:22 AM
