can i use a 60 degree double angle cutter to mill threads on mach 3 using the partmaster pro?
if so how do i go about doing this?
thanks
thanks
Should be no problem. I don't know about your cam system, but you can just use normal G code as well. Your radius will be your major diameter minus the cutter diameter divided by 2. G3 is a helical interpolation if you give a Z coordinate and a lead value as well.
PartMaster Pro (Level 3 in the UK) has a threadmilling function.
Define a Pattern in Cad as though you were going to drill it, then in Cam use the Threadmill item from the main operations toolbar.
Using the standard mach3 post "m_mach3" will output consectutive G02/3 moves with a corresponding move in Z.
I will upload an example program and drawing.
Hope this helps
ATB
Andre
Here is the file.
Thats what I was going to say. Use the threadmilling option in the cam.
yes, i played with it some this morning and got it about figured out.
now to start on either the rotary or z profiling next?
