AKJ1325H AccTec CNC thin stainless steel laser cutting machine is no doubt a revolutionary product that can be used to cut both metal and non-metal materials.
This stainless steel laser machine could cut 0-1 5mm SS, 0-2 5mm Carbon steel, 0-28 mm acrylic and 0-25mm wood. It has a working area of 1300*2500mm and cutting speed of 0-20000mm/min. It has imported servo motor along with an imported ball screw transmission that improves its response speed.
The machine uses a constant light system that achieves high precision cutting of the whole area. Other features are, easy to operate, low maintenance cost; adopt sealed co2 laser tube and smooth cutting section without processing again.
Among many metal and non-metal laser cutting machine, AKJ1325H is superior in quality and provides superior performance.
