587,482 active members*
3,458 visitors online*
    Jul 2009
    12
    THC For Mach who has the boards?
    I would like to put THC on my new table who has them and what do i need ? Is it a 4th axes ?
    Feb 2007
    4553
    Post
    555e,
    Contact Tom Caudle "Torchhead" he is a member here on the Zone.
    http://www.candcnc.com/
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2005
    2415
    The MACH integrated THC logic lets you have a full Z axis for any type of cutting. By adding a cost effective DTHC module our Breakout/Interface product (MP3000) can turn the Z into a full interactive Digital Torch Height. You can switch from using Z for other 3 axis cutting, milling, drilling to DTHC in a simple profile change in MACH.
    You can use your 4th axis to build a nifty rotary axis for pipe cutting! All you need is a full controlled XY and Z with separate motors and drives.
    We have everything from board level products to full blown 5.5 axis stepper or servo controllers. You can buy in at any level of system.
    TOM Caudle
    www.CandCNC.com
    Totally Modular CNC Electronics
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. Need two boards cut
    By freejac in forum PCB milling
    Last Post: 06-28-2009, 02:14 AM
  3. Flashcut to Mach conversion: boards?
    By jtodd in forum FlashCut CNC
    Last Post: 04-04-2008, 12:50 AM
  4. Flashcut to Mach conversion: boards?
    By jtodd in forum Machines running Mach Software
    Last Post: 03-25-2008, 05:00 AM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
