All righty! I am upgraded to Level 3. I got the text figured out, but when I generate the code, it will only mill the slant part on the letter "N". It is not milling the two vertical legs. I tried to set this up as Precision Text in the mill module and also as an Engraving on the CAM module. It ends up with the same result in both of them.
And...when it runs the simulation, some of the letters are completely filled in when I Animate it, while other parts of other letters just have a singly blue line.
I am using ARIAL TrueType font if that makes any difference...I tried a "Simple Font" and that was actually worse...
Is there anything I can post that will show what is happening?
Mike
