Testing Bubble Memory: Fanuc 6M
Is there a way of running buble memory tests on a Fanuc 6M?
I'm trying to install a larger bubble memory board in my Fanuc 6M: a few numbers:
Main board is: A16B-1000-0030 / 05C (is this a 6M B2 ???)
(System come up saying its a 6M Series M47 version 10)
Original BMU is: A87L-0001-0016 / 09H (40 metre 16Kb?)
Repacement BMU is: A87L-0001-0084 / 06C (320 metre 128Kb?)
I've installed the bigger card, loaded the defect tables for each device, and been able to re-load the parameters from a file generated using the original bmu. The machine basically works (it's a four axis wire edm machine), but I get one or two oddities. For instance if I do a ref return in X&Y all is well, but U&V can give servo errors or over travel alarms. If I revert to the original BMU it behaves itself.
Admittedly I've not checked every bit of every parameter, but I've spot checked all over the place and found no errors. As well as making a file of the parameters I also photographed each screen on my mobile, which has proved very useful for checking!
So is there a way of running a bubble memory test? I assume that the RAM test on the IL screen is the ram on the main board being tested not the BMU?
Andrew Mawson
East Sussex, UK
