I have that board and I use the XYZ limits (configure as NC) and the Estop
I would like to add Zero plate but I don't know where there is another Input header for the zero plate ...
I was reading the board documentations and they said that pin 15 is an input too however how would I connect to it to give mach3 macro an input...
there is 4pin header designated as: 16,gnd,gnd,17 --but those are output pins according to mach3 :nono: however I did read that one can configure those pin as an input according to the parallel port DB25 standards.
Crap... all I wanted is just a zero plat...any ideas will be welcome
