586,047 active members*
3,830 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Tapered hole - how to drill/route without a reamer?
Results 1 to 9 of 9
    Jul 2013
    51
    I have a few small tapered holes I need to route, but as it's not a job I'll be doing often I don't want to purchase a tapered reamer, I'd rather do it with a small router bit in several passes
    However I cannot seem to find a Camworks feature that will allow this, any suggestions?
    I've tried doing a hole and clicking recognize tapers but cannot get it to work. It just profiles the hole as a straight cylinder
    Mar 2008
    111
    Re: Tapered hole - how to drill/route without a reamer?
    Multi surface feature, then and a z level style tool paths.
    Jul 2013
    51
    Quote Originally Posted by jame5m28 View Post
    I've been unable to get this to work, I keep getting the following error and don't understand how to rectify:
    Toolpath not generated because there is no Contain Area or Avoid Area is larger than Contain Area
    In an effort to get around this I've added an avoid area, does not fix. I've added a contain area. Does not fix. I've tried using much smaller cutter bit, does not fix. I've reduced all offsets to zero, does not fix.
    Jul 2012
    12
    You can always use a calculator.
    May 2005
    15
    Quote Originally Posted by demonx View Post
    That should be a pretty straight forward multi surface tool path. I would chose Legacy finish mill, Z-level, and Face if I were doing that. I don't think you need to apply an Avoid Area or Contain Area. You may be having an issue with tool path "resolution." I'm not at work so I don't remember what Camworks calls that. I almost always use .0001 to get the most accurate tool path. Let us know if you are still having difficulty.
    Jul 2013
    51
    Quote Originally Posted by Harvdog42 View Post
    Thanks for the reply
    I'll have another look at it tomorrow when I'm near CamWorks.
    Cheers
    Jul 2013
    51
    Thanks heaps for the reply, I was able to get your steps to work, I did have to replace the "face" with "core" and select "with cavities", but yes, I finally have managed to get a tool path to fit these tapered holes
    CamWorks is simple once you understand how it works, but the more time I spend on it, the more little hurdles it throws at me, but each time I'm learning from them and I'd be lost without you guys, so thanks again!
    May 2005
    15
    Demonx,
    Using "Face" worked for me. I modeled something similar to the tapered hole you presented and applied the Z-level multi surface tool path. See below. Click on the image to enlarge it.
Name:	Tapered Hole Example.jpg
    Jul 2013
    51
    Demonx,
    I'm not near a PC to check it at the moment, but I'm guessing the difference might be the tapered holes in my model are at the bottom of a slight circular untapered extrusion which is hard up against a radiused top surface, thus the tapered hole itself is not up against the face?
    Not sure, but I do know the rest of your method got me there, but I had to change away from face.
  1. Drill bit to Reamer
    By octaneman in forum MetalWork Discussion
    Last Post: 01-16-2012, 01:47 AM
  2. tapered hole
    By o1dakota440 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-22-2011, 11:24 PM
  3. Hole Comes out Tapered HELP.
    By Cartierusm in forum MetalWork Discussion
    Last Post: 07-12-2009, 02:09 PM
  4. drill before route???
    By jp_dt in forum PCB milling
    Last Post: 10-31-2008, 10:05 PM
  5. tapered hole
    By dshowald in forum Milltronics
    Last Post: 05-01-2007, 05:19 PM
