The reason you get the alarm is that the control is set up to not just hang if there is a M,S,T code does not complete, it times out and tells you essentially that the control did not get a finish signal for the operation, IOW although the chuck opened there could be a switch of some kind, pressure or otherwise that tells the control it has completed the function.
Check the schematics etc for prox or pressure switch.
Al. .
Albert E.
