Hi. I've searched around first, but couldn't find an answer.
The mill is advancing about .01" in X- & Y- in about 1k lines of code.
I'm running Mach3 R1.84.000, 8 IPM. Xylotex drive & 269 oz in steppers, 1/8 step.
Taig is 2019CR-ER.
I followed the directions on:
http://www.cartertools.com/nutback.html so B/L should be fine,
I've checked w/ an MDI also, as in Mach manual (50x back & forth)
I set the nuts so I they were tight, but I can hand turn ok.
The gibs are good, I've done a lot of reading on how to set this thingy up.
I'm also not clear if I can set the B/L to a pos / neg in Mach.
Any advice is greatly appreciated.
Shawn.
