I would like I build a simple computer controlled desktop CNC machine. It will be for cutting circuit boards. I realize that saying simple is probably a bit off. This is my first undertaking with stepper motors. It is not my first endeavor into wiring or mechanical projects. I am an engineering technology student at purdue so I should be able to handle it. But I have several questions that I'd like some help with when it comes to motor control.
I would like to build my own board first off. Limit switches would be nice but to start with, but it will not be required. The unit from lintrix has a very nice board but inhave been unable to find the schematic. After I get it running I can cut circuit boards and make a more complicated board or a better one. Probably will make a second machine. The instructable below is what I am loosely basing my project off. The motor controller used is a little odd with the lights but I will include them anyway. But my question is, will this board work well? If not can someone suggest a better schematic to use?
One last question. Can I use this parallel port board with an adapter for USB and not run into problems that can't be overcome?
http://www.instructables.com/id/EJ3KFVBF5R8QRL3/
Any suggestions or tips would be awesome. Hope this is in the right place. I have used search and scrolled through numerous posting but haven't found what I needed.
PurduePete
Sent from my iPhone
