In the next day or so hopefully I'll be taking possession of a "new to me" mill. It has one small glitch that I'm aware of immediately (and probably more that I'll learn about after I try to use it). Someone went a little too low on the table and milled it a bit. Is this something that:
a) I should be worried about?
b) that can be repaired? I have a TIG and I was thinking if I just heated the table up with a torch a bit and then filled it in and sanded it smooth, I could probably fix it. But I don't know if the heat will hurt anything else but I would worry about just TIGging a big chunk of metal like that without pre-heating it a little.
Any suggestions...I searched and didn't really find anything.
