587,661 active members*
3,277 visitors online*
    Oct 2006
    36
    Table display screen reversed?
    The table layout screen in the upper right corner of mach3 screen, everything is reversed. If my part I want to cut is in the upper left of the table layout,it will actually cut the part in lower right on my table. Don't think this is normal ,is there a way to reverse this? The cursor crosshair is also reversed. I tried to do it with my machine settings but did not work. Thanks Brian
    May 2007
    4
    Did you find a solution
    I was wondering if you found a solution to the reversed image.
    35538
    Sounds like one or more axis are moving in the wrong direction.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. Y axis reversed
    By Legion99999 in forum Syil Products
    Last Post: 03-04-2007, 06:43 AM
  3. Don't hurt the noob ... 1 axis reversed, help
    By oddatwl in forum Xylotex
    Last Post: 02-14-2007, 07:35 AM
  4. Set the counter display
    By hien100881 in forum Fanuc
    Last Post: 09-22-2006, 05:26 AM
