587,201 active members*
2,832 visitors online*
Results 1 to 2 of 2
    T32-3 no M commands after reinitialization
    Hello,
    I have this problem. After we lost parameters due to a faulty battery I did a reinitialization procedure for T32. I pulled parameters from the eeproms, Cleared all the areas to finally start the machine without any alarms, BUT I could not send home, SO I had to re-establish the home position with an instruction manual that I downloaded from the mitsubishi website. FINALLY, after numerous attempts the machine made it to the home position.
    NOW, MY PROBLEM NOW IS I can not get the chuck to open and close AND I can not turn the coolant ON and OFF in MDI mode. The chuck works fine in manual mode
    Any ideas?
    Thanks for the help
    jolulank
    www.doctornumerico.com
    cnc physicians
    Jan 2019
    2
    Re: T32-3 no M commands after reinitialization
    Parameter R49
  1. T32-2 reinitialization procedure parameter retrieve
    By jolulank in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-26-2017, 04:52 PM
  2. T32-2 reinitialization procedure parameter retrieve
    Last Post: 09-24-2013, 05:27 PM
  3. Who gives commands here?
    By Take-it-easy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-22-2011, 10:25 PM
  4. Dos Commands
    By LYN BYRD in forum Milltronics
    Last Post: 08-01-2011, 04:21 PM
  5. G2 and G3 Commands
    By Bohemund in forum G-Code Programing
    Last Post: 05-28-2007, 03:12 PM
