587,345 active members*
4,019 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > T32-2 reinitialization procedure parameter retrieve
    Hello,
    I have a QT15 With mazatrol T32-2 with parameters lost. I been told that this machine has the parameters backed up in EEROM but I do not know and can not find the procedure on how to retrieve these parameters, if anyone has any information and can share it I will really aprecciate it.
    jolulank
    Sep 2008
    93
    Jun 2017
    5
    Re: T32-2 reinitialization procedure parameter retrieve
    Hello guy, do you have the parameters for this machine? I have a Mazak SQT-10 with mazatrol T32-B and batery died. Thanks a lot!
  1. G10 to set, what to retrieve and then save to variable ?
    By iMisspell in forum G-Code Programing
    Last Post: 05-29-2014, 04:18 PM
  2. T32-2 reinitialization procedure parameter retrieve
    By jolulank in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-24-2013, 05:27 PM
  3. Replies: 3
    Last Post: 05-19-2013, 09:21 PM
  4. parameter unlock procedure osp 5000L
    By Gtmachine in forum Okuma
    Last Post: 03-03-2013, 08:45 PM
  5. Machine parameter edit procedure for FANUC 6T System
    By VENKATESH REDDY in forum Fanuc
    Last Post: 10-13-2011, 10:56 PM
