587,262 active members*
3,573 visitors online*
Results 1 to 8 of 8
    Mar 2013
    15
    T-816 transformer
    Does anyone have a t-816 transformer, I have one that the voltage for servo drives has one leg that is only putting out 20v?
    Mar 2013
    15
    Is it possible to eliminate the transformer all together, I have 230v coming into the machine?
    Apr 2005
    345
    I eliminated mine, on the VMC15XT.......
    Depends what VFD drives your spindle, and what power your amps need to run the motors.......
    http://www.scpconcepts.com
    Jan 2010
    59
    Are you sure all of your taps and jumpers are in? If not this could be your issue. I would pull and check your jumper and tap wire for broken or missing copper.
    I have not personally seen a transformer fail in this way. But thats not a lot of exp. talking.
    '93 Fadal VMC-40
    Fadal 88 Control
    Jul 2010
    0
    The transformer retaps proper voltage to your drives, but it also taps down your voltage to 110/120 for everything else. I would take Jet's advice and recheck your wiring. In 10 years, I have seen only one bad transformer.
    Jan 2010
    59
    I Came Across this Exact Issue Today LookingFor A Different Issue. This Happens When The Drives Are In Estop, It Pulls One Leg Down When Referencedp Phase To Phase.Something To Do With The Solid State Relays. Anyway, Just An Fyi. Sorry FOr The Retarded Caps, App Is All Fubar ATM
    Oct 2015
    12
    Re: T-816 transformer
    @danielboone What did you end up finding that caused your problem? Dealing with the same issue. Thanks!
    Jul 2005
    7
    I know this thread is very old, but for those that might be looking, T-816 transformer supplies 3-phase 86V AC to the DC amps board for conversion. What ever you do, if you wish to keep your DC amps this must be dealt with.
  1. What is this transformer
    By cncpartstx in forum CNC Machine Related Electronics
    Last Post: 08-25-2011, 04:38 AM
  2. where to buy a transformer in the uk
    By derkiow in forum Stepper Motors / Drives
    Last Post: 12-15-2010, 08:48 PM
  3. transformer
    By lgalla in forum Stepper Motors / Drives
    Last Post: 12-13-2010, 03:33 AM
  4. One big transformer or three?
    By koslaz in forum CNC Machine Related Electronics
    Last Post: 10-14-2006, 01:06 AM
  5. transformer hum
    By kra in forum CNC Machine Related Electronics
    Last Post: 02-11-2005, 09:58 PM
