587,568 active members*
3,270 visitors online*
Results 1 to 4 of 4
    Aug 2010
    24
    System Floppy disk M32
    Hi
    I am running Mazak AJV18 with mazatrol M32 control. while running the machine the system disk (3.5" Floppy) is scratched and now I can not run the machine. Whenever I turn on the machine, it goes to alarm. Following description is written on the Floppy. System No: BND-212W001-C1
    Does someone has a same floppy or is there any way to recover or copy the data from my scratched disk.
    Jul 2007
    284
    I beleive the disk is in a special format that cannot be coppied with a regular PC. You will have to get a copy through Mazak or Mitsubishi.
    Oct 2013
    62
    Re: System Floppy disk M32
    You ll actually need a special M32 simulator and the number written on your scrap floppy so MITSUBISHI can issue a new one.
    Jun 2012
    36
    Hi Pcreek,
    You have not mentioned what alarm you were getting while switching on the machine
  1. Floppy disk drives
    By Wjman in forum DNC Problems and Solutions
    Last Post: 08-13-2014, 06:49 AM
  2. How to make system floppy disk LB15 OSP500L-G
    By cyberbond in forum Okuma
    Last Post: 01-27-2011, 06:23 PM
  3. Floppy disk will be discontinued.
    By l u k e in forum Haas Mills
    Last Post: 05-16-2010, 12:51 AM
  4. Floppy disk going bad and replacement question
    By smithgrind in forum Fadal
    Last Post: 12-18-2009, 08:16 PM
  5. Anyone ever use floppy disk drives?
    By Bill Johns in forum Stepper Motors / Drives
    Last Post: 03-16-2005, 12:02 PM
