587,913 active members*
3,672 visitors online*
Results 1 to 2 of 2
    Apr 2006
    125
    Syntax check???
    Hi Scott,
    I don't think NCPlot will check for this?
    There's a thread on emastercam about missing a parenthesis on a 30 fanuc control with big consequences.
    One Little Typo, One Big Crash - eMastercam.com
    Someone says that vericut can check for this - it may be worth looking to implement the same feature?
    Cheers,
    Terry
    765
    I wasn't even aware that some controls would allow multiple line comments! Thanks for the heads up, I will be adding this...
    Scott
  1. Mach 3 syntax checking
    By equack in forum NCPlot G-Code editor / backplotter
    Last Post: 01-13-2010, 01:12 AM
  2. Need help with VB script Syntax Please.
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2008, 01:18 PM
  3. Need a bit of help identifying some syntax
    By ethyrial in forum G-Code Programing
    Last Post: 07-24-2008, 03:05 AM
  4. syntax error
    By pyroracing85 in forum G-Code Programing
    Last Post: 01-28-2005, 02:09 AM
  5. Syntax question
    By doug6949 in forum Mastercam
    Last Post: 12-13-2004, 08:14 PM
